how should i build my lq4?
Old Mar 8, 2013 | 02:01 PM
kmbordere's Avatar
Registered User
Default how should i build my lq4?
i have a 4.8 06 chev single cab. i am in dfw and will get junkyard lq4. money is a concern so trying to decide if i should buy rotating assembly and have a shop build 408 short block with new cam, stock heads, stock intake. or use stock short block and spend money on heads and intake. what do yall think? if i could afford both i would. hoping for 500 crank hp but would like strong tq #. will be a daily drvr. def not track only.
Old Mar 8, 2013 | 02:30 PM
nonnieselman's Avatar
What kinda budget numbers are we looking at?
Old Mar 8, 2013 | 03:18 PM
Atomic's Avatar
I have a gauge for that
Stock bottom end, good heads and cam and torque converter with stock tbss intake and you will be good to go.
Old Mar 8, 2013 | 03:59 PM
darnie's Avatar
x2 you should be over 400 to the ground with that
Old Mar 8, 2013 | 04:58 PM
dirt track racer 81's Avatar
Stock bottom end and l92 heads with a decent cam.
Old Mar 8, 2013 | 08:51 PM
shawnss's Avatar
If money is an issue I'd do a stock bottom end and put the money in a cam and heads. A short block build can get pricey in a hurry. what is your overall budget? I will tell you I had a budget set for building my 408 and Im almost double into what I had first budgeted. there is a ton of little supporting mods you don't think about that all add up.
Old Mar 12, 2013 | 01:36 PM
dirty_old_chevy's Avatar
Stock shortblock, ported 799/243 heads, descent intake, cam and headers should get you there. Oh, and you will probably run out of injector.
lxcoupe
Sep 6, 2017 08:24 AM
Knightcrawler
Jul 20, 2016 03:29 PM
6.0l RST
Nov 23, 2015 11:30 AM
MA$TER_E
Sep 9, 2015 03:14 PM
