How much can you safely mill 799/243 heads?
Old Feb 18, 2016 | 06:52 PM
TAPyvehc93's Avatar
Default How much can you safely mill 799/243 heads?
This is on a 2011 5.3 with factory flat top pistons with valve reliefs. Running a 224/228 cam.
Old Feb 18, 2016 | 10:42 PM
1ownerCHEVY's Avatar
Ive milled .020 and had no issues. Just needed shorter PRs. Measure to be on the safe side
Old Feb 19, 2016 | 08:49 AM
TAPyvehc93's Avatar
What size cam and do you know what that put your CR at?
Old Feb 19, 2016 | 02:57 PM
dirt track racer 81's Avatar
I've milled .050 and been fine
Old Mar 3, 2016 | 06:35 PM
bobfig's Avatar
Mine are milled. 030" anything past that can start to get intake sealing problems.
Old Mar 8, 2016 | 08:57 PM
TAPyvehc93's Avatar
Thats what I've heard. What did that put your compression ratio at?
Old Mar 8, 2016 | 09:43 PM
bobfig's Avatar
should be around 9.9:1 with the stock gasket (.051") on a 05 lm7 with the dished pistons. with the flattop pistons that should be in your truck you should already be at around a 10:1 ratio.
if you milled to a chamber of 61cc (~.020-.024") you would bump up to 10.5:1
stayed stock and got thinner .040" gasket and a .010" cleanup mill would net you 10.5:1 and have a better quench.
Old Mar 8, 2016 | 11:41 PM
Not to highjack, but Im wondering the same thing about my compression ratio. I have an ly6 with the dished/valve relief pistons and 799s milled .020. Ls9 gaskets .051 i believe. Where would this put me at? 10.2?
Old Mar 9, 2016 | 05:14 AM
bobfig's Avatar
my calcumalator says somewhere around 10.5:1
Old Mar 9, 2016 | 07:15 AM
Choda's Avatar
Good info here. So at what point did you guys decide on getting them milled? Sounds like you have aftermarket pistons. I have stock rotating assembly and about to tare mine apart for a mild build/update. Is it worth having the shop mill them down a bit or stick with the " just touch them to ensure they are flat " approach?
