How does your 212/218 lope?
Old Jul 27, 2009 | 04:38 PM
I like the sound the cam produces, doesn't lope much but you can sure tell it's not stock.
Old Jul 27, 2009 | 04:42 PM
JakeBrakeIH's Avatar
yes thats what I liked about it as well...I had the truck running at work getting ready to leave and the UPS driver was like does that have a cam? (he had a G8)
like you said its just enough, but not too obnoxious for a DD
Old Jul 27, 2009 | 04:43 PM
00ChevyScott's Avatar
Wearin' da big hat
how can a cam be too obnoxious
Old Jul 27, 2009 | 05:04 PM
robt342003's Avatar
this is exatly what im looking for
Old Jul 27, 2009 | 05:10 PM
obnoxious when you start it and its shakin ur teeth out when u just wanna get to work in the AM...by the comment I made, for someone who is looking for a cam that will not cause driveabilty issues etc, and make decent power with...its spot on
Im sure you have your own opinion on what a good cam is too...for what I used my truck for, it worked excellent...
Old Jul 27, 2009 | 05:35 PM
SincalT/A's Avatar
Keep it on a 114.I say that cause after time you will want forced induction.If you want more lope turn the idle down 100rpm when you get a tune.
Old Jul 27, 2009 | 05:49 PM
robt342003's Avatar
will a turbo not work, or just not be as efficient with the lower lsa?
Old Jul 27, 2009 | 05:53 PM
it will work, but not as well...turbos or any FI application tend to like wider LSA cams...114 or bigger is most common
Old Jul 27, 2009 | 05:54 PM
PathfinderJr's Avatar
nope. the lower lsa's will bleed off cylinder pressure more so than a higher lsa due to the valve events. and when you're trying to force air/fuel down into the cylinder, you're almost shooting yourself in the foot if you bleed off too much.
Old Jul 27, 2009 | 06:17 PM
robt342003's Avatar
meh, for now I would rather have that nice cam sound
