How do I get the sludge out of head bolt holes?
Old Mar 27, 2008 | 11:53 AM
stock48's Avatar
9 Second Truck Club
Default How do I get the sludge out of head bolt holes?
Im changing my head gaskets, and instaling head studs. Im having a horrable problem with this nasty sludge down in the head bolt holes. I can't get it out. The studs hydrolic, and ooze that **** out between the head and gasket, when I try to install the studs. I tried to suck it out with the vaccume, and blow it out with the air, but it is too thick. I need to find some way to suck that **** out. I will appreciate any ideas. Thanks, J
Old Mar 27, 2008 | 12:06 PM
jkwalkercchs's Avatar
loosin it up with some degreaser first
or try tranny fluid
Old Mar 27, 2008 | 12:17 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd put some trans fluid in there and scrape around with a screwdriver to break it up... then try vacuuming it again.
Old Mar 27, 2008 | 01:03 PM
Silver LT's Avatar
I have used industrial "Q-Tips" to reach into bolt holes. Sometimes a regular Q-Tip with a straight Kelly Clamp. Also a smaller diameter screwdriver with a patch of cloth. A guncleaning kit might work too; a brass wire brush on the end of a rod.
Attached Thumbnails How do I get the sludge out of head bolt holes?-78110cta%5B1%5D.jpg
Old Mar 27, 2008 | 01:11 PM
PappyDan's Avatar
Tribe Shaman
you need a very small round metal brush.
the kind that look like a large pipe cleaner.
hook it up to your drill, squart in some cleaning fluid,
stick it and and spin it while moving up and down.
blow it all out with compressed air.
Old Mar 27, 2008 | 02:49 PM
OnyxSilveradoSS's Avatar
file your old bolts flat on two sides and use that as a cheap tap tp loosen it up and keep sucking it out.
Old Mar 27, 2008 | 03:20 PM
TXsilverado's Avatar
beat me to it....i put some pb blaster in the bolt holes to loosen up the junk too. just thread that bolt in and out until it threads in with your fingers and the bolt comes out clean.
Old Mar 27, 2008 | 06:01 PM
thunder550's Avatar
High on diesel fumes
How did the sludge get down in there to begin with??
Old Mar 27, 2008 | 07:27 PM
stock48's Avatar
9 Second Truck Club
Thank's guy's I sprayed some carb cleaner down there to thin it out, and twisted up some paper. It's seems to be absorbing.
Old Mar 27, 2008 | 07:28 PM
stock48's Avatar
9 Second Truck Club
I have no clue. It is a horrable pain in the *** though.
