How to disconnect fuel line?
Old Feb 23, 2007 | 03:34 PM
Yogi Bear's Avatar
Default How to disconnect fuel line?
How do I disconnect these fuel lines? We're doing an engine swap and we need to pull the fuel lines to get the intake manifold off. We already have the clips off.
Old Feb 23, 2007 | 03:45 PM
blake2kz71's Avatar
you do it with a fuel line seperator but you dont need to take them apart to take the intake off. 1 fuel line goes to the passenger side of the intake and its held down with a small bracket and a screw. on the driver side i believe there are 2 lines that go into the fuel rail with the same style bracket and screw. remember to get some rags ready and release the pressure before you do this. also there are blue o-rings that are on the lines up under the brackets and they may or may not come off when you pull the lines off. they are small and easy to lose.
Old Feb 23, 2007 | 03:47 PM
thunder550's Avatar
High on diesel fumes
Go to a parts store and get a set of fuel line disconnect tools. Or do what blake said above.
Old Feb 23, 2007 | 03:50 PM
Yogi Bear's Avatar
thanks, but I'm trying to get the "bosses" off from the fuel line. It's the round chorome looking fittings. I did a search and found an old post about cutting an old hose clamp off and shoving it in there to release the clips.
sounds like this guy
https://www.performancetrucks.net/fo...ight=fuel+line
Old Feb 23, 2007 | 03:57 PM
TurboGibbs's Avatar
Like said above, all parts stores carry them. Go to one and ask for a fuel line disconnect tool. They are sized for the diameter of the line so you will need 2 different ones(3/8" and 5/16" I think) or a set with several.
Old Feb 23, 2007 | 04:04 PM
Yogi Bear's Avatar
OK Going to the parts store. Thanks for the help!
Old Feb 28, 2007 | 11:02 PM
blake2kz71's Avatar
sorry for the late reply but i went and bought one b/c i thought it was required but i got home and got to taking it apart and realized they didnt need disconnecting. the bolts/screws have torx (star) heads so dont strip them out trying to use a allen wrench, that would be a pita trying to get them out. so you are wanting the end pieces of the fuel lines??
Old Mar 1, 2007 | 10:54 AM
Yogi Bear's Avatar
We were trying to separate the flex lines coming up from the firewall from the hard pipes on the manifold. Got the special tool from the parts store and got it worked out. Thanks anyway!
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
MWRitter
Jul 27, 2015 09:41 AM
76k10chase
Jul 17, 2015 01:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
