How bad is it? retorque rockers...
Old Nov 17, 2007 | 10:00 PM
parish8's Avatar
single digit dreamer
Originally Posted by IMD
you're you're you're. its not that hard people!!!
Old Nov 18, 2007 | 01:03 AM
MikeGyver's Avatar
To, too, two funny.
Old Nov 18, 2007 | 10:32 AM
Derek @ EDO's Avatar
FormerVendor
This is why loctite should be used, I torqued mine down 22ft lbs rotated blah blah blah and when i was left onside the road thinking my engine was about to blow because of a loose rocker i will not think twice about using Loctite next time lol.
Old Nov 18, 2007 | 05:33 PM
eallanboggs's Avatar
How hard is it to pull the coil packs and rocker covers? Not very. If you do them in pairs(by doing 2 cys. at a time and then rotating the crank 90 degrees) you can just torque them as you go along and go back and retorque the ones you've already installed. That way by the time you get to the last pair you've already torqued and retorqued them all several times. The last ones I did were a set of the new Scorpions which they don't recommend any locktite on. If your using the OEM rockers and insist on locktite you should put the locktite under the OEM bolt head. This is the way GM does it(orange stuff under bolt head flat washer). That way the threads don't get gummed up with locktite. It's a good idea when you think about it if you plan to use locktite. Of course, this means the boss that the bolt bucks up against must be clean and dry(no oil).
Old Nov 20, 2007 | 08:39 PM
Onetogofast's Avatar
When I did my cam swap, I left the coils on the covers and the covers came off fine.
Old Nov 20, 2007 | 09:39 PM
Tootall's Avatar
if you used loc-tite, then you "should" be ok . . . but if you didn't I'd pull the covers, clean up the bolts, and start over.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
