How bad is it? retorque rockers...
Old Nov 17, 2007 | 04:41 PM
TouchOfEvil04's Avatar
Default How bad is it? retorque rockers...
Well i realized just the other day that i never roatated my motor to retorque the rockers.
I put em in torqued em to 22in lbs and went on about my way.
Question is how bad or what could happen from this?
Is it that important to rotate the motor then retorque em?
Old Nov 17, 2007 | 04:44 PM
Derek @ EDO's Avatar
FormerVendor
your good, you put loctite on em!
Old Nov 17, 2007 | 05:12 PM
parish8's Avatar
single digit dreamer
your suppose to loctite them?
Old Nov 17, 2007 | 05:18 PM
Darknight-4's Avatar
I don't think you torqued them down to 22 in lbs...maybe ft lbs
Old Nov 17, 2007 | 05:28 PM
22 ft lbs and locktite! I rotated the motor and retorqued as well.
Old Nov 17, 2007 | 06:11 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
All the cam swaps I have done I have never had a problem with just tq'ing them to 22ft-lbs except for once with ap2002's truck, just put some loctite on em and tq'ed em down again and it was fine until he pulled the motor.
Old Nov 17, 2007 | 09:19 PM
I was just wodering as i knew you were supposed to do so. Wasn't sure if i should worry about it or just move on.
Old Nov 17, 2007 | 09:34 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Here's what I recommend:
1. Torque all 16 rockers to 22 foot pounds.
2. Rotate crank 1/2 revolution and retorque to 22 foot pounds.
3. Repeat step 2 two more times.
Blue Locktite is optional. The reason you want to rotate is to take the pressure off the spring/pushrods that are being compressed by the cam lobe so that you can properly torque (set up the clamping force) onthe rocker arm assembly. It's good that you thought about this. Likely, you've done no harm.
Steve
Old Nov 17, 2007 | 09:38 PM
IMD's Avatar
IMD
Banned
you're you're you're. its not that hard people!!!
Old Nov 17, 2007 | 09:46 PM
Gator's Avatar
yea, i just used a ratchet by feel without loctite 15k miles ago....but if i have the VC's off in the near future i'll use a little blue locktite and a trq wrench
