Higher CR VS Lowere CR and higher boost for a 408
Old Oct 24, 2012 | 03:53 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by AKlowriderZ71
Forgive me if I'm wrong(and please correct me if I am), but 408 stroker and big boost numbers don't play well together IIRC. Too much skirt below the hole @ BDC, with high boost won't it kill pistons relatively quickly?
I dunno about that Roger. Many people are in the 2x psi range on 408s with no internal problems.
Old Oct 24, 2012 | 03:56 PM
I AM A MOTHERF*CKER
My truck is at 8.65:1 and I had no trouble with around town driving. Also, what are you exact numbers for CR and boost you want to run?
Just noticed you're running an SC. I'd definitely do higher CR for that application. But the difference between 10:1 and 9.5:1 probably won't be noticeable when you are out of boost.
Old Oct 24, 2012 | 07:15 PM
LsF-150's Avatar
Completly agree with this, a half point drop you wont notice out of boost but it will help a bunch with how much timing/boost you can get away with. I would go no lower than 9:1 and no higher than 9.5:1. I've been planning a 408 with boost and have been going down the same path as you. Your running quite a bit more cam than I will. Good luck with the build
Old Oct 24, 2012 | 08:19 PM
SSmikeSS's Avatar
good info guys
it looks like no e85 then
I really dont have a hp, boost, or cr goal. I just don't want to limit myself. I would like to have room to grow without blowing up my motor again. lol
So you suggest 9:1-9.5:1 cr? I think my heads are 72cc(?) I'll have to check my paperwork. I'm not even sure if my driver side head is salvageable. I'll have to post some pics tomorrow.
Thanks again for the good info. looks like I have a good start for a plan.
Old Oct 26, 2012 | 11:44 AM
SSmikeSS's Avatar
Here are the pics.
Yes that is a crack.
Do you think the head is salvageable?
Attached Thumbnails Higher CR VS Lowere CR and higher boost for a 408-no-piston.jpg   Higher CR VS Lowere CR and higher boost for a 408-damaged-head.jpg
Old Oct 27, 2012 | 10:15 AM
SSmikeSS's Avatar
A local builder/machine shop says they can resleave that cylinder and go from there. It's a pretty reputable shop. I don't like the idea. I like new. Is the resleave that bad of an idea? Also they said the head could be salvaged. It would be a cheaper option.
I was thinking of buying a short block or long block minus the heads from Texas Speed.
Does anybody have any money I could have (not borrow)
GXPJAY
Feb 13, 2022 08:15 AM
chevy6.0fan
Aug 20, 2015 07:10 PM
therock
Aug 20, 2015 02:31 PM
steves86ta
Jul 28, 2015 10:21 AM
