Help reading my Plugs
Old Feb 14, 2016 | 02:18 PM
GreatWhiteBuffalo's Avatar
Default Help reading my Plugs
Ok so last night I ran the nitrous on my truck for the first time. 200hp wet shot. Removed timing from my original N/A tune and is now currently sitting at 23*. Did a few pulls, truck ran great and pulled like a freight train. Did noticed that my AFR's are a little on the rich side ranging between 11.8 - 12.1. Pulled a few plugs to get an average reading. As you can see on the ground strap, my timing line is almost perfect as it sits almost center of the bend. The strap is a nice golden brown color between the timing line and tip of strap, however between the timing line and threads, it's a chalky white. And I noticed a little bit of peppering on the porcelain, which would usually be from detonation, but I think my timing is a little on the retard side. Could this peppering be from running a little rich or possibly oil detonation? I'm running 91 octane
Old Feb 14, 2016 | 02:55 PM
George C....'s Avatar
Formerly ScreamingL
200 shot you should be on higher octane
Looks like a 7 series plug
Id swap to a 8 series for 200 shot
Old Feb 15, 2016 | 11:56 AM
TrendSetter's Avatar
im no plug genius, but it looks like youre showing signs of detonation on the porcelain.
i suggest finding the nitrous plug reading thread on yellowbullet.
Old Feb 15, 2016 | 01:52 PM
dirt track racer 81's Avatar
Too rich and too much timing.. Those Pistons won't last long. On an .082 jet you need to be around 18-19 degrees timing. Your timing mark need to be on the very tip of the strap, not the whole strap.
TrickTurbo
Apr 11, 2016 09:54 PM
Slow91z
20
Feb 15, 2016 03:51 PM
dr_whigham
Feb 14, 2016 12:05 PM
stealthperf
Feb 11, 2016 12:24 PM
vipergtrdj
Feb 8, 2016 05:24 PM
