Help needed with choosing pistons for my 6.0L
Old Oct 2, 2017 | 08:36 PM
5.3oilchugger's Avatar
5 Year Member
Default Help needed with choosing pistons for my 6.0L
I'm having my 6.0L gen4 block bored to clean up a slightly worn cylinder #6. I'm thinking .020" will clean it up but might have it bored .030". I'm lost as to how piston domes and inverted domes are measured. Is a factory piston the baseline for + or - cc? I'm trying to find a piston set that will keep the compression same as stock with a 4.020"-4.030" bore. I find summit racing's website confusing. Any help would be greatly appreciated.
Old Oct 2, 2017 | 09:01 PM
grey matter 04's Avatar
13 Second Truck Club
I used speed pro 4.030 pistons part#H1128CT75MM in my budget build. Hyperutectic piston with coated skirts. Not forged anything special but a good replacement for $250 .
Great for a mild build
Old Oct 2, 2017 | 09:32 PM
MikeGyver's Avatar
I don't think that you should worry about the minimal compression increase that would come from a .030" over bore.
Old Oct 3, 2017 | 06:18 AM
5 Year Member
The stock pistons have a slight dish in them with valve reliefs. Finding a piston exactly the same .030 bigger is a sure challenge. I checked GM parts and GM offers a piston .5mm over sized but that's less than .020" and their $65 a piece.
Old Oct 3, 2017 | 10:22 AM
The ones I listed are stock replacement and stock compression. They have a slight dish just like the factory piston .
Attached Thumbnails Help needed with choosing pistons for my 6.0L-img_0017.png
Old Oct 3, 2017 | 09:34 PM
5 Year Member
My stock pistons have a dish like the one you have pictured but with two valve reliefs. Is the valve relief for vvt engines. I'm doing away with the vvt
