Help me gather supplies for a 243 swap into my 5.3!
Texas Speed has a head bolts and gaskets. Get the GM MLS head gaskets (not graphite). The GM gaskets are all one thickness. If you want a thinner gasket, you need to get Cosmetic (but, they don't seal as well as GM).
Since you have a 2004 engine, you have to figure out which bolts to use (they changed mid year in 2004).
I did cam and 243's on my 5.3. I am lucky enough to have it on an engine stand, but here is what I used while doing it and everything went smoothly.
For general instructions on the swap I used this how-to:
LS1Howto.com
It's for an F-body, just skip the parts where they take the car apart.
You will need to buy a pushrod length checker tool and this is how you use it
LS1TECH - View Single Post - correct pushrod length
For tightening the rocker arms I used this thread (post 34, should go straight to it).
Corvette Forum - View Single Post - COMP Rocker Trunion Install
It's for an LS1 or LS6 but you can use it on any LS engine with the same firing order.
Edit- I went with GM MLS head gaskets and they were marked 5.7L. Just a slightly bigger bore, but it will not make much of a difference.
LS1Howto.com
07NBSChevy
20
Jul 8, 2015 07:27 PM
