help i have no idea whats going on!!
Old Sep 24, 2007 | 10:03 PM
navy_ao_05's Avatar
well the oil is clean and no metal. guage says 0psi. I think its the oil pump( which it shouldnt be seeming i bought it from texas speed). steve bryant since your in the wichita area if you wanted to swing by and put your in put in it would be helpful(i can also pay you for your time)
thanks to everyone for there help!!
Old Oct 1, 2007 | 12:02 AM
navy_ao_05's Avatar
im ordering a new oil pump tomorrow
Old Oct 1, 2007 | 12:17 AM
CHEVRACER83's Avatar
did you confirm the lack of oil pressure with a mechanical gauge??
Old Oct 1, 2007 | 07:47 AM
Grumpy5.3's Avatar
I may be wrong on this but i am pretty sure you need the kent moore adapter tool to check pressure on these engines. I have tried to do it through the sender port, but it has a really funky thread pitch to it.
Old Oct 1, 2007 | 01:39 PM
navy_ao_05's Avatar
no i didnt check it with a guage. i dont have one. or know how to.
Old Oct 1, 2007 | 01:42 PM
IF YOU HAVE A LOCAL DEALER.... GO TALK TO A HEAVY LINE TECH... MOST OF THEM ARE COOL AND WILL CHECK IT REAL QUICK FOR YOU IF YOU DROP THEM A 20 OR SO
Old Oct 1, 2007 | 01:45 PM
Did You Hear Any Noises From The Engine When It Went To 0 Oil Pressure? You Should Hear A Lifter Tap Or Something.
Also I Have Seen Some Clusters Go Bad And The Oil Gauge Reads 0 Or Sticks.
Also I Believe You Should Have A Switch That Kills Your Fuel Pump If Oil Pressure Is At 0.
Old Oct 1, 2007 | 06:37 PM
navy_ao_05's Avatar
i can hear the lifter tap.and it sounds horrible dont know how to explain it.
Old Oct 1, 2007 | 07:39 PM
adam1803's Avatar
Don't start it up anymore until you get the oil pump replaced. Hopefully that'll fix your problem but i wouldn't count on it. You may get oil pressure back but i'll be willing to bet you'll have a knock still.
calsdad
Jun 14, 2023 11:07 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
00loudchevy
Dec 3, 2015 05:54 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Cammed4ever
Sep 30, 2015 03:38 PM
