help
Old Dec 2, 2008 | 03:51 PM
whitegmc2002's Avatar
Default help
i have a 2000 chevy v6 1500 it has a new fuel filter..the truck is hard to start.. its spins over strong and started doing it after the filter was changed by a machanic shop bc it went in for the trans acting up and the fuel filter fixed the problem..
Old Dec 2, 2008 | 04:09 PM
chevrolet all the way's Avatar
so it dont crank with the new fuel filter? make sure its on good and dont use a candle to find out...
Old Dec 3, 2008 | 01:25 PM
terravast4's Avatar
when you crank it over can you hear the fuel pump humming or just the engine turning over? I had a 2000 4.3 and the fuel pump did not last long in that thing.
Old Dec 3, 2008 | 01:50 PM
Yogi Bear's Avatar
Get a fuel pressure gauge and check your pressure. Should be 58-60 at key on engine off, 56-60 while cranking, 52-55 at idle, and 60-62 at WOT.
Old Dec 3, 2008 | 02:53 PM
thanks I'll try. It's a work truck with about 290000 miles it might be time for a new one
Old Dec 4, 2008 | 08:06 AM
litreddevil's Avatar
Banned
check cap and rotor very common
