Heads & Cam Specs...Help & advice pls!
Old Nov 14, 2006 | 09:31 AM
dhpro's Avatar
Originally Posted by FarmerBeau
I never knew they made 1.6 ratio rockers for an LS1 I think you are spending a lot of money and not taking advantage of your setup. What is the purpose of spending all of that money on a set of rockers when you could just grind a cam for half the amount and get virtually the same valve events and use the stock rockers? Basically what im asking is, besides being different, why?
Agreed...thats why I'm trying to get advice and opinions here. I'm kinda stuck with the elements listed and hoping they will all mate up properly. I wud rather not just thro cash at it, but instead try and find a combination that works right the first time. If I goota thro out some or all of these parts then I will, but....R/
Old Nov 14, 2006 | 09:45 AM
FarmerBeau's Avatar
Sexy Party Mod
Forget rockers unless you are going all out and want to pay 600 bucks to be able to adjust your preload. I just dont see the power/money ratio weighing in very heavily. Stock rockers are efficient enough. IMO
Old Nov 14, 2006 | 09:47 AM
dhpro's Avatar
Thnx...thats what I was hoping to hear...I was gonna try just transfering the stock parts first. R/
Old Nov 14, 2006 | 12:59 PM
onebadrubi's Avatar
get you a better cam to take full advante of your heads/blower.
Old Nov 14, 2006 | 02:37 PM
02sierraz71_5.3's Avatar
I personnaly think that you can run more compression and be fine with that blower. That style blower isnt known for producing large amounts of boost especially in a free flowing setup if you look at older SBC they ran 10:1 with the weiands around 10 psi and made great power on 93. I wouldnt be scared to run 10:1 with that blower especially if you arent going over 10-13psi just make sure the quench is where it need to be.
I would add more lift to that cam thats probably why those guys were thinking about 1.7 rockers.
I wouldnt worry about the heads you have, 10psi is alot more flow than 28" which is where those numbers came from.
my .02
Old Nov 14, 2006 | 06:39 PM
Quik's Avatar
5 year bitches!
Originally Posted by onebadrubi
I think quick was saying that about the cam because that amount of lift is fine on stock heads. If you are going with aftermarket heads you can step it up in the lift on the cam to take full advantage of the head flow.
yes!!!!
Old Nov 15, 2006 | 10:27 AM
dhpro's Avatar
Thnx for the input guys!! As for the cam changes...can u guys recommend any exact #'s I shud be aiming for if I opt to go that way? Its a little easier to stomach a diff cam than heads! R/
Old Nov 15, 2006 | 01:15 PM
onebadrubi's Avatar
with that cubic inch I would be looking at something close to .590-.600 lift atleast. But im far from being any cam expert.
JFortner5
Aug 12, 2015 08:46 PM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
4B11T
Jul 13, 2015 03:48 PM
