which heads for 6.0 swap
Old Jan 10, 2006 | 09:38 AM
Default which heads for 6.0 swap
i've got a 6.0 shortblock im going to put into my rcsb and it is head-less right now. i won't be anything to special my 221 cam and a stall etc.
my question is what heads and head gaskets should i go with?
I thought i could just use the heads off my 5.3 with 6.0 head gaskets, does this sound allright? compression?
Another question i know the 4.8 and 5.3 heads have 1.89" intake valves correct, well i have some 2.00" valves i can put in there, is this worth it? will i have to modify the head any?
thanks guys
Old Jan 10, 2006 | 01:35 PM
mwalls54's Avatar
Need More N2O Mod
which 6.0 do you have? LQ4 or LQ9
Old Jan 11, 2006 | 11:53 PM
Richard@WCCH's Avatar
FormerVendor
You have several choices for cylinder heads. It's possible to install the 2.0" intake valves into your 5.3l heads and if done properly would make an affordable setup that will yield high compression. By my estimate your compression ratio should end up near 10.75:1 depending on head gasket choice. That's a bit high when used with a 220º+ duration cam. It will drive the cylinder pressure over 180psi and that usually leads to a pinging condition. Shoot for 10.0:1 cr if possible. A 66cc chamber volume will get you there.
Incidently, we have a CNC program to make the 5.3l chambers 65-66cc. We can also install the 2.0" intake valves as well. Feel free to call us at the shop anytime if you'd like to chat about your setup.
Good luck,
Richard
Old Jan 12, 2006 | 12:19 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I bought the new DART LS1 casting heads for my 418 and they are a very nice piece I started a thread on em in teh gm exhaust section and there are pics in the link in my sig
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
