which heads for a 6.0
Old Feb 22, 2009 | 12:55 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default which heads for a 6.0
well im stuck between two pairs of cylinder heads for my 6.0 build
the PRC 220cc 5.3 2.5 cnc ported heads or the patriot performance cnc ported ls6 heads both have 59cc chambers and both have 650 lift dual springs the ls6 heads flow alittle better but are also 150 bucks more.
btw im running a stock lower end LQ9 with a tsp 228r cam.
Old Feb 22, 2009 | 11:24 AM
Ryan02SS's Avatar
I ran Patriot 5.3's on my LS1. No problems and a great head for the price. I've never dealt with PRC but I hear they make quality parts. IMO the 5.3L head would be the better bet for your setup. It should have a smaller higher velocity port than the LS6 head resulting in better overall power with your cam selection. A larger cam would work better with the LS6 heads.
Old Feb 22, 2009 | 12:20 PM
built408's Avatar
have never used any, but the prc's are proven heads and there are plenty of good numbers put down in the dyno section, especially on the tech side. You might want to give those a look before you buy either set.
Old Feb 22, 2009 | 01:00 PM
so you think the 5.3s are a better choice thats the ones i was looking at
Old Feb 22, 2009 | 02:15 PM
00Silv4.8's Avatar
do the stage IIs if you've got the money. I didnt so I did LS1s, probly need a good porting but better than the stock cast iron BS
Old Feb 23, 2009 | 05:31 PM
sickREDsierra's Avatar
patriot heads leave a lot on the table, JMO
i would love either PRC's or TFS heads. both pickup a good bit over a Patriot. i see it on tech too often, folks gaining 20+ rwhp over patriot heads.
and yes, i am running Patriot
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
