head scratch question
Old Aug 29, 2019 | 05:12 PM
pcmcobra's Avatar
Default head scratch question
Intake port on one cylinder on the head has a scratch horizontally. Looks like someone needed the help of a screwdriver to get the intake off or something.
Scratch across gasket area. I'll try and get a pic later. Can the intake surface be "decked" or finished to get rid of the scratch? It probably would not need much.
thanks
Old Aug 29, 2019 | 05:34 PM
madmann26's Avatar
How bad is it?
I used some red scotch bright pads to clean the head/block side and it worked really good.
Old Aug 29, 2019 | 05:46 PM
FFDP's Avatar
Yeah, just hit with a scotch brite pad or some emery cloth. Or a yellow/green fingered roloc wiz wheel disc to clean it up.
Old Aug 29, 2019 | 06:46 PM
pcmcobra's Avatar
sry, forgot my phone. It's not that bad. thx all, will probably just "feather" it and should be fine.
Old Aug 31, 2019 | 09:15 AM
RB04Av's Avatar
5 Year Member
If it's REALLY bad - like, so deep that you think a gasket might not seal it - then take some sandpaper, wrap it around something stiff enough to hold its shape but flexible enough to conform to a shape, like maybe a paint stir stick, and sand off any high edges; then fill it with JB Weld and sand flat.
Old Sep 1, 2019 | 06:17 PM
pcmcobra's Avatar
intake scratch
Old Sep 1, 2019 | 06:57 PM
RB04Av's Avatar
5 Year Member
Can't tell whether it gets into the actual sealing area or not; probably not, but ...
All ya gotta do is, make it flat.
Sand, epoxy, sand again, done. You could maybe even just razor-blade off the high ridges, use a body filler plastic wiper thing to schmear in the epoxy.
Not to be mean, but, you've already spent more time posting on the Internet, than it would take to fix it. Quit posting already and just fix it.
Old Sep 1, 2019 | 07:55 PM
pcmcobra's Avatar
not to be mean, but **** off, in a nice way.
Old Sep 2, 2019 | 10:04 AM
RB04Av's Avatar
5 Year Member
Not to be mean, but... got the scratch fixed?
At some point, ya just gotta DO STUFF. Posting about it on the Interwebz only takes you just so far.
Old Sep 2, 2019 | 10:07 AM
FFDP's Avatar
He just wanted his hand held for a bit.
