Head job cost
Old Nov 18, 2008 | 06:16 PM
POPO1984's Avatar
Default Head job cost
I went to the shop today and talked to the guys there. He quoted me $ 350.00 to PP clean up the exhaust side valves to reduce shrouding is this a good price for just the labor. Also he said he could do larger valves if i wanted for that price.
Old Nov 18, 2008 | 06:47 PM
WorkTruc's Avatar
About $20 on the corner of Crack avenue! (lol) jk
SEROIUSLY YOU SHOULD ALSO GET A 3 ANGLE VALVE JOB AND SURFACE CHECK OR HEADS CUT FOR THAT PRICE.
Old Nov 18, 2008 | 06:50 PM
skeet's Avatar
damn thats expensive lmao!!!!
Old Nov 18, 2008 | 07:05 PM
Breeze's Avatar
11 Second Truck Club
That's a good price for the P & P on the cylinder heads. A lil on the high side for the other head. lol
Old Nov 18, 2008 | 08:17 PM
POPO1984's Avatar
Yeah that did include a resurfacing, 5 angle valve job, and he also said we could mill them if i wanted
Old Nov 18, 2008 | 08:19 PM
POPO1984's Avatar
Im not to sure about the milling though. are there any cons to this. I will be getting a 218/222 comp cam with rods and spring at the same time.
Old Nov 18, 2008 | 08:26 PM
Phantom's Avatar
11 Second Club
Last head job I got cost me about $1100 diamonds are expensive
Old Nov 18, 2008 | 08:31 PM
silver-mod-o's Avatar
Hunt&Fisherator
You left yourself wide open on this one... That's reasonable on the headwork.... If you mill double check pushrod length before you order.
Old Nov 18, 2008 | 08:35 PM
POPO1984's Avatar
ok i will check that. any suggestions or info on milling the head i know it will raise compression but will i need to adjust any other things to run at a higher compression.
Old Nov 19, 2008 | 06:19 AM
skyhighsami's Avatar
no title here
My machine shop said 450 to PnP, mill, 3 angle vavle job, and work the combustion chamber on my 317s.
