Head Gasket Problems..
Old May 4, 2008 | 10:12 PM
dirt track racer 81's Avatar
Default Head Gasket Problems..
My motor has been torn apart for a few weeks and just had the head gaskets layin around on my drive way..while i was cookin some burgers on the grill i was lookin down at them noticed the exhaust gases have been leaking by on 1,3,5,7 and 4,6,8 cylinders..i used arp rod bolts and the gaskets i told my machine shop to get some .040 head gaskets..they came in a felpro box..they look like stockers so whats yalls opinion..
Old May 4, 2008 | 10:17 PM
TurboGibbs's Avatar
Those markings look very typical to the 4-5 boosted engines that i've torn down. I imagine nitrous could cause the same head lifting issue.
Those are stock 6.0L gaskets that measure ~.052" compressed. Those are the same one's I get from the dealer.
Old May 4, 2008 | 10:27 PM
thats what i thought they were..they were packaged in felpro gaskets..i only ran maybe half a bottle of 175 shot through it..could the heads possibly been warped? they have never been milled..
Old May 4, 2008 | 10:47 PM
TurboGibbs's Avatar
I doubt the heads are warped. As I said, looks normal to me from what i've seen. The castings are very thin and the deck surface distorts under high cyl pressures.
Old May 4, 2008 | 10:49 PM
so im pretty much fubarred
Old May 4, 2008 | 10:53 PM
TurboGibbs's Avatar
No, make sure the heads are flat and put it back together and run it.
Old May 4, 2008 | 10:59 PM
ive pulled the ls1 heads i had on it and ive gotten some ls6 heads that will be milled that im gonna slap on it
Old May 4, 2008 | 11:03 PM
Stoichiometric's Avatar
TurboGibbs, will you start to push water before the exhaust begins to leak like this? How much farther could that engine have been pushed before the gasket failed (assuming no detonation)?
Old May 4, 2008 | 11:08 PM
hirdlej's Avatar
It almost looks like you overtightened the heads causing the area between the bolt holes to bow upwards and not seal. Similar to overtightening a thermostat housing.
Old May 4, 2008 | 11:11 PM
heads were torqued in sequence and to stock specs, i seen no detonation on efilive and i had 110 in it
