head gasket
Old Nov 10, 2011 | 04:46 PM
ou812sm's Avatar
Default head gasket
Who makes the best head gasket for ls engines
Old Nov 10, 2011 | 04:50 PM
Phantom's Avatar
11 Second Club
for what kind of use?
stock mls gaskets work great
Old Nov 10, 2011 | 05:53 PM
andrew383's Avatar
traveling mod
I vote stock GM MLS gaskets..
Old Nov 10, 2011 | 06:18 PM
dmelvin's Avatar
Unless you're wanting other than the standard .051 thickness go with this, if you're wanting to go to with a thinner gasket, I've had no troubles with my Cosmetic MLS gaskets.
Old Nov 10, 2011 | 06:37 PM
ou812sm's Avatar
How about cosmic gasket
Old Nov 11, 2011 | 07:04 PM
terravast4's Avatar
GM mls gasket
Old Nov 11, 2011 | 08:35 PM
whitedakota's Avatar
Terravast4- how good does your truck run?! Oh btw mls gaskets ftw.
Old Nov 12, 2011 | 09:38 AM
budhayes3's Avatar
PT's Slowest Truck
I believe you guys mean "Cometic" gaskets
I like the GM MLS gaskets myself, and my second choice would be the thinner, more expensive Cometics. If it's an eary 5.3, the GM MLS's won't work as there is a notch or something in the head that will leak if the factory graphite gaskets aren't used. Not sure what years/casting numbers this applies to, but I know that this info is floating around here somewhere.
Old Nov 13, 2011 | 08:01 AM
ou812sm's Avatar
How about fel pro perma torque mls head gasket are they or cosmetic head gasket better I would be using the new head gasket on ly6 (6.0) I want to use a .40 ths gasket
Old Nov 13, 2011 | 11:56 AM
dmelvin's Avatar
I do that every time. My phone doesn't like the word Cometic.
My '02 had MLS gaskets, so it would of had to of been earlier than that for the graphite gaskets.
