Head Bolts vs Head Studs
I know alot of guys are boosting stock bolts to 15 psi with out issues. I opt to go with the ARP bolts. Some times it is better to push a gasket then it is to blow the *** up, hahaha
yea im not gonna push it up to the 5 gazillion psi limit.. but i would love to try 15psi..
Jarrett said bolts would do me fine, they gotta be alot stronger than stock TTY's and i have seen quite a few folks doin 12-20psi on them.
I wanna try an do it right the first time.
lifters and trays, rockers, LS9 Gaskets, all the above.
For 15psi I would at least want the ARP bolts. You might even consider the studs but it would be more of a peace of mind kind of thing. Anything over 20 would be where I would say studs are required.
Studs are well over double the Bolts so thats hard to get past.
