Head Bolts vs Head Studs
Old Aug 1, 2012 | 11:24 AM
  #21
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by DTHPROOF
I used ARP bolts. Like already said, up to 15psi is bolt territory. No way in hell I would throw eBay studs in anything but a junkyard motor lol. They might be awesome, but if I boofooed a block because I put generic studs in it, I'd be sick with myself.
There's a metric **** ton of people using the eBay studs with good results. Especially now with the ARP bolts breaking I'd feel more comfortable with the eBay studs. If one of those broke you'd have a lot better chance of getting it out of the block than an ARP bolt.
Old Aug 1, 2012 | 11:27 AM
  #22
Phantom's Avatar
11 Second Club
Same
Used them in my first 5.3 with 15-16#
Used them in my 6.0 with lots of nitrous
Used them in my 383 with LOTS of nitrous
Used them in my second 5.3 with 15#
Using them in my 347 with lots of boost
Old Aug 1, 2012 | 11:56 AM
  #23
Mangled03gmc's Avatar
Baltimore Whore
Are these the 65-80$ studs?
Old Aug 1, 2012 | 12:05 PM
  #24
Hivelocit's Avatar
Paid $254 shipped from autoplicity. Power is addictive, and I didn't want to limit any potential HP goals down the road!
Old Aug 1, 2012 | 03:42 PM
  #25
slowec's Avatar
I am sure I will do studs soon too. My issue is why not inch up the boost ssssslowly until it pushes coolant. cool off , back off boost and order studs. Kinda like the dont fix what aint broke approach.
Who has ruined any hard parts pushing coolant out of the headgaskets?
Old Aug 1, 2012 | 04:40 PM
  #26
Ferocity02's Avatar
The issue is when you do get to lifting the heads it can damage the head gaskets and cause you to push water at a lower boost or all the time.
Old Aug 1, 2012 | 06:03 PM
  #27
1slow01Z71's Avatar
Nevermind when you push water if you do it good you will spray coolant all over the ground. Have fun keeping it lined out at WOT with only one tire going through a puddle. No way in hell Id purposefully find the limit that way.
Old Aug 1, 2012 | 06:36 PM
  #28
DTHPROOF's Avatar
I'm glad you guys have good results, just saying they're not for me.
Old Aug 1, 2012 | 08:34 PM
  #29
stock48's Avatar
9 Second Truck Club
Kyle torched his head, but block was ok I think...
Old Aug 8, 2012 | 09:51 PM
  #30
Chevy_freak's Avatar
Out of curiosity, why is the block junked when you break a head bolt? Has anybody tried extracting one? Ill assume the block is too thin to use a mill and bore the bolt out and try re-tapping.
