GT2-3 Cam....what else?
Old Aug 16, 2006 | 07:36 AM
Dub Silverado's Avatar
Default GT2-3 Cam....what else?
Alright im ready to order my Lingenfelter cam to go with my radix. What else will I need? I know I need Push Rods, and 918 Springs but what else?
Oil Pump
Retainers
Locks
Timing Chain
etc?
Let me know so I can get this all lined up.
Old Aug 16, 2006 | 07:41 AM
thats all you should NEED honeslty but if you want you can get some new retainers and locks. you might wanna post this over in FI so those guys can chime in
Old Aug 16, 2006 | 08:00 AM
I dont want to spend more than I have to but I also want to have a safe setup. I dont need to break anything.
Old Aug 16, 2006 | 08:15 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
springs and pushrods thats it your oil pump is new, t-chain is fine since its new also, locks and retainers dont really wear especially not with how new your truck is. My 180K 5.3 locks and retainers looked the same as my comp ones I put on except the oil residue obviously.
Old Aug 16, 2006 | 08:28 AM
Alright, i just order the 918 springs and the 7.4 pushrods by comp. Now I need to find out where to get the cam for the best price.
Also, how about injectors. You think the ones that came with the radix are going to be sufficient? I dont know what my duty cycle was when I tuned.
Old Aug 16, 2006 | 08:30 AM
1slow01Z71's Avatar
Probably have to step up to 60s. Most max them out with a small pulley/cam.
Old Aug 16, 2006 | 08:42 AM
KySilverado's Avatar
I wouldn't do retainers and locks. Gaskets (water pump, front cover), new harmonic balancer bolt.
Think the only place you will find the cam is direct from LPE.
Old Aug 16, 2006 | 09:26 AM
Ok, so i need the timing chain cover gasket, and also the water pump gaskets correct. What about valve cover gaskets?
Also, im awaiting the crank pin kit from magnacharger so I think that includes the new bolt that was spoken of above. I will wait to pin the crank until the cam is installed.
What do the rest of you think about the injectors? Where is the best place to find the ones ill need?
Old Aug 16, 2006 | 09:46 AM
im sure if you run through all the sponsors to the right you will not have any trouble finding one that sells 60# injectors.
Old Aug 16, 2006 | 09:52 AM
I looked but all im finding are 42#
