good news bad news...took engine apart
Good news: Bottom end is still good
Bad news: Lifter failed and took out cam
Good news: Get to try a different cam and lifters
Bad news: Have to decide which ones to get
Current Ppecs: P/P 317s Harland Sharp 1.7s, Manley Nextek .660 lift double springs, Manley 7.35 pushrods, REV 1.65/2.02 valves
Broken stuff: Comp high energy lifters, Bullet Racing cam 224/228 114 .570
i had a sending unit issue i think...well might have been from this. but the noise started long after the oil pressure scare. the roller is also loose in the lifter...might have lost a needle bearing...or the failure in the roller may have caused the bearing to go out. either way just happy its not bottom end...
considering the GM Racing Caddie CTSVR lifters (250 @ SCPC) and the LEP maggie cam 224/230 .612 116
, you going to try GM lifters now?
