good head for 5.3
Old May 12, 2011 | 10:28 PM
06murder's Avatar
damn i wana make some power out of the 5.3 cuz im maken it my drag/street truck....which part is to big?
Old May 12, 2011 | 10:33 PM
05gmcsierra's Avatar
that cam.. if u plan on going on a big cam u need a big converter.. ive seen people run 228 duration cams on 3800-4000 converters.. if u dont plan on going that big on a converter i say u stay with something in the low 22* duration.. ur set up needs to match up.. conveter with cam and have all the other supporting mods.
Old May 12, 2011 | 10:41 PM
dmelvin's Avatar
The bigger cam you go (bigger cam is defined by longer duration more so than the lift). The bigger the cam the less power/torque you have in lower RPM's, which is crucial in our heavy *** trucks. In a 5.3, I'd go no higher than a 22x/22x without a stall, some guys won't put any cam in the 5.3 without a stall. On a 6.0, I'd go high 220's - mid 230's at the most.
The cam you listed would be best suited for a light camero or vette with at least a 402 IMHO
06murder's Avatar
wanting an round an 3500... stall with th350
Old May 12, 2011 | 10:43 PM
dmelvin's Avatar
To match a 3500 stall, I'd go with something similar to the TR224. Which when you build it, should be a pretty decent cam for your 6.0 too.
Old May 12, 2011 | 10:45 PM
Originally Posted by dmelvin
the bigger cam you go (bigger cam is defined by longer duration more so than the lift). The bigger the cam the less power/torque you have in lower rpm's, which is crucial in our heavy *** trucks. In a 5.3, i'd go no higher than a 22x/22x without a stall, some guys won't put any cam in the 5.3 without a stall. On a 6.0, i'd go high 220's - mid 230's at the most.
The cam you listed would be best suited for a light camero or vette with at least a 402 imho
we thinking alike..
Old May 12, 2011 | 10:47 PM
06murder's Avatar
i was thinking that or th 228r frm tsp..when i get the 6.0 (lq9)put an ms3 in it n put the 224-228 in the dd truck n its going lq4 llater too
Old May 12, 2011 | 10:48 PM
LISTEN to this guy.. same thing i would say.
Old May 12, 2011 | 10:55 PM
06murder's Avatar
what bout tsp 224?
Old May 12, 2011 | 11:02 PM
dmelvin's Avatar
Originally Posted by 06murder
what bout tsp 224?
It's a very similar grind to the TR 224, go for it
