good camshaft HELP
Old Aug 8, 2006 | 09:15 AM
graysilv's Avatar
Default good camshaft HELP
hey guys i was wondering what cam do you all recomend for a 5.3?
i have the following mods
3.90's
vette servo
3000 stall
headers
gibson exhaust
CAI
p/p tb
Old Aug 8, 2006 | 09:41 AM
bluecajun5.3's Avatar
11 Second Truck Club
220 to 225 duration range
.550 to .588 lift range
112 or 114 lsa
Old Aug 8, 2006 | 10:08 AM
Tractionless's Avatar
TSP's "Sleeper" Cam on a 112 or 114 LSA. LINK
Old Aug 8, 2006 | 10:15 AM
silver-mod-o's Avatar
Hunt&Fisherator
for you.. TR220 or if you wanted to go bigger a TR224... the TR220 tuned properly in that truck will scream... just look at bluecajun's times. Low 12.50's without any power adders... ya cant really argue with that. your 3000 stall will work well with it too!! if you go 224, get it on a 114LSA, you wont be disappointed that way either but it will require a little more tuning to make run and drive correctly.
Old Aug 8, 2006 | 12:56 PM
Bad_Apple's Avatar
i agree TR 220 LSA 112.... with your stall and gears will pull strong with a good tune.
Old Aug 8, 2006 | 05:21 PM
nightmarechevy's Avatar
I love my 224 so far but I have a 3400 stall. It is a 224/224 581/581 114 LSA. It doesn't really lope at all when it is warmed up, really sleeperish actually.
Old Aug 8, 2006 | 08:24 PM
02sierraz71_5.3's Avatar
If your not going with an adder overlap/compression are your friends keep the lsa, ICL tight and around 220 duration like others have said Id also mill the heads about .04-.05, angle job
If you dont go with long tubes I would bias the exhaust like a 214/222 on a 110 .560 ish lift
Old Aug 8, 2006 | 10:59 PM
budhayes3's Avatar
PT's Slowest Truck
I'm thinkin TR220/112
Old Aug 8, 2006 | 11:39 PM
I am installing a XE275HR .222/.224 .566/.568 112 from COMPCAMS this is a good cam if you are going to us the magic gas (NOS). Make sure to get matching components like the springs, pushrods, valve locks, retainers, lifters, timing chain and rockers. That if you want the works or just go with cam springs and pushrods like many do. Also get a ported oil pump for cheap insurance.
Old Aug 8, 2006 | 11:48 PM
FarmerBeau's Avatar
Sexy Party Mod
im thinking custom grind around those numbers up top on a 110 lsa!
