Gen 1 Small chevy 400cid
Old Jul 8, 2007 | 06:32 PM
old motorhead's Avatar
Default Gen 1 Small chevy 400cid
I'm going to look at an old truck that supposedly has a 400cid small block chevy under the hood. If I remember right, you could identify the 400 block because it had an extra freeze plug on each side. Seems like a smaller small block had 2 freeze plugs vs 3 on the 400. Or was it 3 vs 4? Help appreciated. I'll probably buy it anyway, but I'd like to know what I'm looking at.
Old Jul 8, 2007 | 07:15 PM
YenkoST's Avatar
The freeze plugs are the same number but a good way to tell is that on a 400, the freeze plugs are offset....one is toward the bottom on the block instead of in the middle.
Old Jul 8, 2007 | 07:18 PM
kbracing96's Avatar
Another way to id a 400, is that its externally balanced, and the harmonic balance will have a big chunk missing out of it and there will be a counterwieght on the flex plate.
Old Jul 8, 2007 | 07:28 PM
I do remember the externally balanced bit. All other small blocks are internally balanced. Didn't know it was that easy to spot on the balancer. Thanks.
Old Jul 8, 2007 | 07:41 PM
mred's Avatar
easiest way isthe block around the freeze plugs stick out the have i guess you call a hump around the block 2 humps usually meant 2 bolt 3 meant 4 bolt
but not always
casting number
330817..... 400...72-80...2
3951509....400...70-71...4
3951509....400...74-80...2
hope this helps
Ed
Old Jul 8, 2007 | 08:37 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
330817 73-76 Passenger, 75-80 Trucks 2 bolt main + 3 freeze plugs
3951509 73-76 Passenger, 75-80 Trucks 2 bolt main + 2 freeze plugs
3951511 330817 73-76 Passenger, 75-80 Trucks 4 bolt main + 3 freeze
plugs
Old Jul 8, 2007 | 08:59 PM
Where is the casting # located? Thanks.
Old Jul 8, 2007 | 09:02 PM
EXTREME's Avatar
the dipstick is on the drivers side, correct me if i'm wrong.
Old Jul 8, 2007 | 09:25 PM
mred's Avatar
so is a 350
Old Jul 8, 2007 | 09:27 PM
YenkoST's Avatar
Unless is an ext. balanced 383. You will see the last 3 digits on the block.
