Gear drives
Old Aug 4, 2010 | 01:06 PM
terravast4's Avatar
Gear drives sound like ***!!
Old Aug 4, 2010 | 04:56 PM
MikeGyver's Avatar
Originally Posted by Evil SS 2006
... use a timing belt system because the accuracy and rotating mass cannot be beat at those RPMs...
Is anybody using a belt on a daily driver? Would it endure?
Old Aug 4, 2010 | 05:21 PM
kbracing96's Avatar
Mike think about this for a sec.... What do almost ALL overhead cam 4 bangers use for driving the cams from OEM?...
Old Aug 4, 2010 | 05:25 PM
Daryn's Avatar
Formerly darynC-10/23/10
not to mension the 2jz's that come in the 4th gen supra's !
Old Aug 4, 2010 | 06:25 PM
MikeGyver's Avatar
Ha, ha, ha, ha, ha, duh. Sometimes I get pretty narrow-minded.
Old Aug 5, 2010 | 09:56 AM
easyrider ls6's Avatar
Why would anyone want to do a gear drive? The whole reason gear drives came about was because the chains in normal timing sets were not able to be made strong enough for sustained high RPM's without massive failures due to slack and stress on chains...Stretch in chains were causing pistons to hit valves in high compression, high RPM engines.
Nowadays, you have a lot better technology going into the parts and single roller timing sets for LS engines are a lot more precise and rigid than even double rollers of yesteryear! (Yes, I said yesteryear!)
If you are going to be spinning 9,000rpms or better, just go all the way and use a timing belt system because the accuracy and rotating mass cannot be beat at those RPMs...
I dont really have a particular reason for running a gear drive. Just thought it would be something out of the norm. Just trying to be a little different.
Old Aug 5, 2010 | 12:59 PM
Truckshop's Avatar
Too much metal to metal contact. You would have to disable the knock sensors to keep it from pulling timing.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
thunder550
Oct 8, 2015 04:53 PM
TimDave217
Aug 24, 2015 04:38 PM
Ketis
Jul 23, 2015 12:37 PM
