forged 370 oil pressure issues
Old May 10, 2015 | 05:49 PM
  #31
lukn4trbl355's Avatar
My oem was green as well as for this oil pressure issue and using the black o ring I take it this could be mu issue?
Old May 10, 2015 | 05:50 PM
  #32
1-87 chevy's Avatar
sounds like a cam bearing issue .
Old May 11, 2015 | 04:10 PM
  #33
I'm hoping not but I wouldn't be suprised. Cam bearings can knock only when hot? I talked with my coworker and he thinks it's no lower end since it only do it hot. Said mains will knock hot or cold as well as rods. I can't even think clearly ny brains tired of guessing. I'd hate to pull it out and find out I overlooked something as small as an o ring. Also I did find out that I got the wrong specs for the retainer plate...saw in a thread anything over 12ft lbs cracks the plate mines at 18...
Old May 11, 2015 | 07:09 PM
  #34
subeone's Avatar
do not use anything other than the green O ring for truck pickup tubes, yes that o ring could cause low oil pressure, in fact, no o ring causes 0 oil pressure, if there is not an adequate seal, oil pressure will be "lost" through there
Old May 11, 2015 | 07:12 PM
  #35
GMCtrk's Avatar
Isn't the motor already damaged regardless of the cause?
Old May 12, 2015 | 05:35 AM
  #36
Subeone thank you sir. Andgmc that's what I was thinking after spending what I did in just pulling it and sending it back. It started knocking again yesterday
Old May 12, 2015 | 05:58 PM
  #37
Well the builder is taking it back. Here's the video lol
Old May 13, 2015 | 10:20 AM
  #38
gagliano7's Avatar
Why is your harmonic balancer pulley so out of whack? Does not sound good.
Old May 13, 2015 | 12:18 PM
  #39
darkirish63's Avatar
That puppy is toast...I'm not sure I'd go back to the same shop that jacked up the build the first time but hey...who knows. Good luck - post a new vid when you get the block back.
Old May 14, 2015 | 03:03 AM
  #40
subeone's Avatar
thrust bearing took a **** ?
