Finally ordered the pistons and rods.
lurius what kind of numbers are you expecting out of it? Which intake are you gonna use? Fuel system? Trans? Reason im asking all these questions is soon il have something very similiar.
-Lurius
PS: I am spraying this motor, so I may go with a standalone fuel system for the nitrous eventually, otherwise I may need to do more fuelign upgrades at some point.
GFYS and STFU
Originally Posted by Lurius
Transmission is going to be built by TRT turbos, I have talked with them a couple times through PMs and they say their 4l60e's are holding up to FI motors alright, so i'll give it a go.
Also you said your going with a 3500 stall, is this your DD or not?
Originally Posted by Spoolin
You're nuts...I can't see how that tranny is gonna last very long...why not just to the 80e now. For peace of mind if not for anything else.
But yea, Im hoping the tranny holds for long enough for me to save up for the 80E. Actually, I'll message TRT and see if they offer an 80E, if they do then I may have to swap my converter soon and go that route, but I think they only have the 60E's.
-Lurius
yeh thats pretty similiar to what i want. I was thinking vic jr intake, 80e conversion w/ just a few upgrades, not sure on stall yet, same heads also.
-Lurius
I talked to fuddle racing and they recomended the stall to me, i'll give it a go and see how well it turns out, if its not what I want I can always change it later.
-Lurius
-Lurius
Alright, well this is badass.. All the pistons and rods weighed equal to the others! No matching or balancing was needed! The crank was balanced and heres the info card they gave me.
Rod rotating:449
Rod rotating:449
Rod bearing: 49
Rod bearing: 49
Oil allowance: 4
Piston and pin:519
locks(1set): 2
Rings 1 set(Plus rail): 41
Rod reciprocating: 172
Bob weight total: 1734
He said this is pretty light for a chevy SB.. What do yall engine gurus gather from this info?
-Lurius
Rod rotating:449
Rod rotating:449
Rod bearing: 49
Rod bearing: 49
Oil allowance: 4
Piston and pin:519
locks(1set): 2
-Lurius
