Finally I finish
here is the list
z71 2000
-strocker 408 (11:* compression )
-Chevy 6.0 Iron Block
-Callies CompStar Crankshaft 4"
-Diamond Pistons Flat 4.030 bore -2cc
-Eagle Connecting Rods (6.125")
-ARP Head Studs
-Cometic head gasket
-Patriot Performance GM LQ9 Stage III Cylinder Heads
-Cam Magic Stick V.3 237/242 603/609 113 Lsa
-SLP Performance Crank Under Drive Pulley
-Pacesetter 3" QuickTrip Long Tube Headers + Y-pipe
-92 Fast intake
-92 Fast tb
-afe air intake
-COMP Cams Timing Chain and Gear Set, Double Roller, Bilet Steel Sprockets
-4L60E tranny stock with a transgo kit+tranny fluid cooler
-Dhm E-cutouts 3"
-Msd 8.5mm spark wires
-NGK TR6
-TnT EFI wet kit
-SLP 160* T-Stat
z71 2000
-ARP Head Studs
-92 Fast intake
-92 Fast tb
-afe air intake
-Dhm E-cutouts 3"
-NGK TR6
-TnT EFI wet kit
-SLP 160* T-Stat
