finally got my free cam installed
Old Mar 7, 2010 | 08:06 PM
53RUSSELL's Avatar
Would the stock 5.3 head net you a higher cr. But then again ls6 heads flow better. I was just want to know. I'm still rocking the stock heads with with my turbo set-up.
Old Mar 8, 2010 | 05:24 AM
TURBHOE's Avatar
well the ls6 heads flow better but then they were p&p'd so they flow an *** ton better. the truck felt better all the way around. off boost on boost but i think it was due to the better flow and the fact i didn't loose a ton of compression vise using ls1 heads or 317's
when i build a motor for this thing i want the motor mid to high 9's somewhere from 9.5-10.1. then boost it. good tune and fuel should make tons of torque. but i don't plane to have the money for that for a while.
Old Mar 8, 2010 | 05:32 AM
TURBHOE's Avatar
i gotta say with this cam swap my numbers in my ve have changed big time. compared to going from stock to the ls6 cam. all the way from 40kpa and up. i been cruising around with 15.5 and higher afr. wot is almost spot on. i was already rich like 10.5:1 then i just blindly added 4% just to be safe. after a log i found i was 11.8 so i added another 2% iirc and now its a good 11.5 run.
Old Mar 9, 2010 | 11:22 AM
budhayes3's Avatar
PT's Slowest Truck
I like specs on that cam, seems good for your set up...I suppose it could use a little more exhaust duration but I'm sure that it will still be a screamer as it it...it was before
Old Mar 16, 2010 | 09:12 PM
TURBHOE's Avatar
well it was suppose to be a 214/218 but the lsl lobes only go down to a 215 so i went with that. i need to see how far she wants to spin now. i haven't bumped the shift points yet.
all_individual
Oct 10, 2015 10:09 PM
thunder550
Oct 8, 2015 04:53 PM
steves86ta
Jul 28, 2015 10:21 AM
lxcoupe
Jul 21, 2015 02:12 AM
all_individual
Jul 13, 2015 11:01 AM
