Finally got a 6 liter..
Ya, I've been reading hot rod magazine and there article about them. The price isnt really bad either for bare castings.
Going with an LS6 or LS2 casting would get your compression up in the range that you're looking for. You could also search around for people selling the re-worked 5.3L heads (valve size correction and ported) and really build some torque with it. If you go with the L92 heads you won't gain any compression. You will however gain alot of airflow and if you pick the rest of the parts right it will be very strong in the mid to upper rpm range.
that's just on the earlier models...00-01 I believ...MOST 6.0s have a 80e behind them as they come out of hd trucks...all he'l have to do is use the flex plate from his 4.8/5.3...as long as its not and early model 6.0
