a few quick cam install ?'s
Old Jan 2, 2008 | 02:13 AM
jakebdb56's Avatar
Question a few quick cam install ?'s
Basically here's what I've got: LS1 Hotcam with LS6 springs (all came in kit)
Should I go ahead and get hardened pushrods? 7.400" is the correct length for stock motor?
Would TR-55's be recommended to install while I have everything apart anyways?
The dowel rods you put in the front of the block to keep up the lifters, is it 3/16"?
I think that about covers it. I bought the crane cams spring tool so that should help out a bit. Other than that I think I have all the parts I need. Any comments/suggestions would be great
Thanks in advance,
Jake
Old Jan 2, 2008 | 02:29 AM
RandomHero's Avatar
Do answer your first question: it depends. Pushrod size has no correlation with engine size. It depends on the base circle of your cam. On the cam specs it should say the recommended pushrod length.
Your 3rd question: I believe it's actually 5/16's for the pushrods. The LS1howto should say though.
Your second question: In my opinion, it's not needed. I've been rocking the stock bosch spark plus for 12k after installing my cam and when I checked them yesterday they looks darn near perfect.
Old Jan 2, 2008 | 02:35 AM
jakebdb56's Avatar
Thanks for the quick response. I meant to type 5/16" lol, It's too late for me to operate. I'll check the GMPP site again for pushrod length, but do I really need to get new pushrods? I run my motor to 6300 w/out any problems and the new cam doesn't have much lift (.525). I'm not experienced in the valvetrain area so that's why I leave these questions for yall to answer haha.
Old Jan 2, 2008 | 01:13 PM
adam1803's Avatar
Being a GM cam, it is probably a safe bet that the 7.400 pushrods will work fine. I would throw some hardened ones in there while your at it, just for some insurance.
Old Jan 2, 2008 | 02:06 PM
GMGen3's Avatar
+1 for the hardened pushrods.
Old Jan 2, 2008 | 02:26 PM
truckmann's Avatar
I'm with them on the hardend pushrods.... It only take one bent one to f-ck things up.
Old Jan 2, 2008 | 04:29 PM
ZZebes's Avatar
+1000 on pushrods
Old Jan 2, 2008 | 06:14 PM
jakebdb56's Avatar
looks like I'm ordering pushrods.
thanks for the input, sometimes I have to confirm tha im not crazy ha
install should be soon and dyno at the end of the month. now for 4.10's and 3000 stall coming this spring
btw, will the comp cams magnum pushrods do the job?
http://cgi.ebay.com/ebaymotors/ws/eB...m=300186727168
Old Jan 2, 2008 | 10:10 PM
adam1803's Avatar
Those will work fine
Old Jan 2, 2008 | 11:20 PM
jakebdb56's Avatar
ok cool, I've got everything now, looks like next saturday it'll go in.
