The engine is here
#22
Guys, thanks for all the input. Maybe the engine doesn't have 9K miles. Maybe a few more. If it does not much. Other than the varnish which can be cheap oil. Unchanged oil I dunno, the engine is mint. There is some evidence of something going on outside the engine on the drivers side, possibly heat or battery acid. The drivers side valve cover is varnished up and the passenger side is pristine. The oil pickup tube and windage tray had more varnish on it on the drivers side. I have had every rod bearing out of it. They are pristine. I've looked at the bores from the bottom. They are perfect, still have cross hatch in them. The plugs were original and look brand new. There is no sign of wear on rocker arms to valve stem. The intake ports to the heads aren't even carboned up. This is a very low miles engine. I am completely satisfied with it and will do nothing more to it. It is good to go.
Thinking about running something in the first oil change it to clean up the varnish. What do you guys recommend?
#23
#24
Originally Posted by L-EATER
I wouldn't recommend using any kinda flush. These motors are WAY sensitive to tiny particles in the oil jamming up the valve in the oil pump. If you go and break that stuff loose, it could be disaster....been there done that. I would guess that the detergents in Mobil 1 will clean it up for you over time. Now go get it running already !!!!
#26
Rod bolts are in. Oil pan back on.
Attached a picture of the rod bolts in, and first time I've seen the cracked rod so snapped a picture of it.
Did you remove the ferral (sp?) before you put the Katechs in?
#28
Yes, I called it a bushing. It comes out when you tap the original rod bolts out.
Thanks,
#29
Originally Posted by Zick
Ok, just wanted to be sure before I put my set in. I've heard your suppose to but the instructions don't make any mention about it.
Thanks,
Thanks,
#30
