Which is easier??
Old May 21, 2009 | 04:58 PM
Mr. Sandog's Avatar
Originally Posted by 05HD1500
How does the gear vendor work? is it automatic?
Unfortunately, no, it is completely manual.
If I were to get a Gear Vendors OD it would only be to have a 5th gear (overdrive after 4th runs out of steam). Even then, you would have to engage it manually with a switch. It would be a total PITA to use it on a daily basis in between all of the other gears.
For my purposes it would be fine. I would give me all the strength I would need (i.e. Level 5 4L80E + GV OD, which is good to 1200 or 1500 HP/TQ I believe), and an extra gear so I could dive down into a lower rear-end gear like 4.10's or 4.56's.
That way, I could get neck-snapping TQ off the line without having to resort to a loose TC, and still get optimum cruising RPM/mileage at speed. I did the math once and with my tire combo, 4.56's, a 4L80E, and GV OD unit, came up with 1800 RPM at 75 mph. That's the sweet spot for mileage.
Old May 21, 2009 | 10:04 PM
ss454327's Avatar
The Gear Vendor unit is nice except for the fact that it's $3500! I'm almost positive they have a stand alone controller that makes it fully automatic now. I looked into it but they don't have a unit that works with the AWD.
Old May 21, 2009 | 10:45 PM
GMCtrk's Avatar
4.56's with an 80e still is less torque off the line than the 60e with the 4.10s
I wouldn't swap the 80e for a 6l80e. The 80e is a stronger trans and is proven for performance.
Old May 21, 2009 | 11:10 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Gear Vendors has a fully integrated ECU that interfaces with the stock computer.
Old May 22, 2009 | 02:11 AM
Mr. Sandog's Avatar
Well, that's cool. When did they implement this? The last time I spoke with them there was no interface.
Old May 24, 2009 | 10:54 PM
L7 Sierra's Avatar
US Gear has a cheaper version of a OD, but you have to set it before you get above 30mph.
It works fine for just towing or whatever, but lacks some of the coolness of GV's.
06murder
Sep 4, 2015 03:54 PM
spiritfish
Aug 24, 2015 05:04 PM
Sierra1320
Aug 15, 2015 08:04 PM
