dual valve springs
Old May 22, 2007 | 11:19 PM
91_bowtie's Avatar
Default dual valve springs
I've decided to go with dual springs on the new motor, so let me know your thoughts on which ones I should get or avoid.
Thanks guys
Old May 23, 2007 | 10:34 AM
eallanboggs's Avatar
If you plan to install duals youself don't try to do it with a "jaw" type spring compressor. The jaw will only compress the outer spring and leave the inner spring expanded so you can't get the locks out. You'll need a tool such as the Tim's or Vinci/Crane. I have both of them. The Vinci cost 3 times as much, but it does 2 at a time instead of 1. 2 for 1 doesn't directly relate to 1/2 the time to make the swap, but it's close.
Old May 23, 2007 | 11:45 AM
tdrumm's Avatar
I run Crane duals, good to .650 lift and 7000 rpm. They came with Ti retainers, but I did have to get different valve seals. 13K on them and no complaints.
I also used the Crane valvespring tool. Definately the way to go.
Old May 23, 2007 | 08:34 PM
Stoichiometric's Avatar
I am also running Crane duals with the Ti retainers. If you can get a good deal on Comp 921's, those are good springs also.
Old May 23, 2007 | 08:51 PM
I forgot about the Patriot spring, Richard at WCCH sells them. I would call Richard and see which of the two dual sets they offer fits your needs.
Old May 24, 2007 | 10:44 AM
ZZebes's Avatar
Richards are Patriot Gold Duals
Old May 24, 2007 | 02:18 PM
He also has the Patriot Extreme dual spring, I believe the Extreme spring is close to 400 lbs open pressure.
Old May 24, 2007 | 03:50 PM
Lurius's Avatar
I am using PRC dual springs. I got on sale for like 220$ or so at TSP a while back.
-Lurius
Old May 25, 2007 | 11:48 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Exactly what I have. 3 engines have come and gone and still the same springs. The Crane tool is great. It compresses 2 springs at once.
Old May 25, 2007 | 11:53 PM
91_bowtie's Avatar
thanks for the replies guys. I spent today stripping it down and we should be dropping the new motor in tomorrow afternoon.
