dropping oil pan on a 4x4
Old May 13, 2013 | 11:35 PM
white 03's Avatar
Registered User
Default dropping oil pan on a 4x4
So I swapped an lm7 to an l33 and managed to get the one with the hairline cracked oil pan. Can the pan be dropped on a 4x4 without pulling out the front axle?
Old May 14, 2013 | 12:26 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Not in my experience. But pulling the front diff isn't that much work.
Old May 14, 2013 | 01:53 AM
2000chevysilverado's Avatar
Unbolt it amd use jack to lower it down and you can pull pan out then its a pita and time consuming
Old May 14, 2013 | 07:11 AM
white 03's Avatar
Registered User
Does it have to come all the way out or just moved down a lite bit?
Old May 15, 2013 | 01:05 PM
219boone78's Avatar
just down a lil. i unbolted the front diff and pryed it down. make sure to check your driveaxle cv joints when u put the diff back up. it looks harder then it is.
spent21
Aug 19, 2015 02:37 PM
Ls3silverado
Jul 31, 2015 04:22 PM
05SilveradoSS
Jul 29, 2015 08:34 PM
jmarkway
Jul 18, 2015 09:23 PM
