doing away with the pvc valve.
Old Jan 15, 2009 | 09:23 PM
PappyDan's Avatar
Tribe Shaman
Default doing away with the pvc valve.
going to ask here first.
has any one, picked up a second passenger side valve cover.
done away with the pvc system, connected both sides with a T and run a catch can only before the tube connects to the throttle body???
how was your results on block pressure?
how often did the catch can fill up?
Old Jan 15, 2009 | 09:33 PM
BlackGMC's Avatar
Resident Retard
Are you still FI? Do you plan to run breathers too?
Old Jan 15, 2009 | 09:36 PM
PappyDan's Avatar
Tribe Shaman
yeah. just looking for a way to plug the pcv line and vent the block at the same time.
just wondering if anyone running na has done the same thing and used a catch can.
Old Jan 15, 2009 | 09:39 PM
BlackGMC's Avatar
Resident Retard
I think krambo did something similar but he also used the LS6 valley cover.
Old Jan 15, 2009 | 09:46 PM
silver-mod-o's Avatar
Hunt&Fisherator
I still have my PCV but have considered doing away with it like krambo did. Before my 5.3 let go, I was getting a lot of blowby and just ran the pass side cover to a catch can and plugged the TB inlet. It helped quite a bit actually. The can caught quite a bit of oil and stopped blowing oil from my dip stick tube, so I'm taking that as case pressure went down.
Old Jan 15, 2009 | 11:28 PM
ZO6Ted's Avatar
Look up spoolin's old posts from late last year. I think he had some success.
Old Jan 26, 2009 | 03:20 AM
blazedchevy69's Avatar
just do what you was talkin about by two passenger side valve covers with a t take the hose down to a pan evac valve on your exhust it will pull close to 5.5lbs of vac.and your done
Old Jan 26, 2009 | 05:40 AM
Mangled03gmc's Avatar
Baltimore Whore
I didn't do away completly with it, but unhooked it from the pass side all toaether, with good results....
TrickTurbo
Sep 23, 2015 08:41 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
slowec
Nov 11, 2006 05:41 PM
TG02Z71
Feb 27, 2006 09:26 AM
lxcoupe
19
Mar 28, 2005 05:35 AM
