debating on which manifold
Old Nov 14, 2007 | 06:23 AM
joshua022's Avatar
The bad thing about the Weiland is that it is aluminum and supposedly it retains a lot more heat compared to the plastic manifolds that don't.
Thats what I've always heard.
What RPM do you shift at??
Old Nov 16, 2007 | 02:35 PM
xdanny510x's Avatar
i forgot lol at wat rpm mine shfits at ... ill tell u later...i thought aluminum was alwayz supposed to be a lil bit better?
Old Nov 16, 2007 | 05:01 PM
joshua022's Avatar
it retains more heat, which after a few runs causes your IAT to go up and then you won't be getting that cool dense air charge that you want to have.
Old Nov 16, 2007 | 05:56 PM
xdanny510x's Avatar
hmmmm i see... so i htink imma kee the stock ls6 and use that one for awhile until x-mas until i get the 90 fast
Old Nov 16, 2007 | 06:07 PM
joshua022's Avatar
PM me when or if you get ready to sell the stock LS6 manifold.
Old Nov 16, 2007 | 06:15 PM
dirt track racer 81's Avatar
im fixin to get the Professional Products intake for 359..you get the rails too..either the 85 or 96mm intake..the way i see it the heads are metal too and retain heat
Old Nov 16, 2007 | 06:24 PM
joshua022's Avatar
True!! but Your IAT's SHOULD be less with a plastic intake.
You want to have lower IATs to make more power right??
Old Nov 16, 2007 | 07:24 PM
if it makes more power than i got right now im happy with it..every one says its going to kill your power..but no one has proof..show me some proof that it kills power..
Old Nov 16, 2007 | 07:28 PM
xdanny510x's Avatar
yea im with dirt track racer here.... show me the numbers that metal increases temp...cause at one point i was about to get the weiand intake but then came across the ls6 stock manifold.. but if yall can prove that metal increases temp than plastic bring it hehe
Old Nov 16, 2007 | 07:29 PM
joshua022's Avatar
you'll have to find someone that actually has one and ask them if it would consistently run good times or after a few runs and it gets good and hot, it wouldn't run as fast.
As I stated above my arguement is nothing but "hear say" I've never actually experienced it.
I agree anything that makes more power is a good thing though. Keep us posted with your new intake and how your experiences are.
