daytona prototype motor in a truck
Old Feb 10, 2008 | 11:18 PM
jkwalkercchs's Avatar
Default daytona prototype motor in a truck
well i came across a set of daytona prototype internals
3.905 bore(still lookin for some pistons)
6.500 lentz rods
3.185 crank with 1.88 rod journals
im gonna put a professional products intake port matched to a set of 035 stage 3 heads with a ported and polished 90mm throttle body
and maybe some nitrous
around a 11:1 compression ratio
they run a 248/248 .590/.590 106 lsa solid roller
but im thinkin about a trex
how do u think this would go in my lifted avalanche
Old Feb 16, 2008 | 09:33 AM
IMD's Avatar
IMD
Banned
seriously? i couldnt think of a worse choice of engine set ups. you want to put a roadrace motor in a lifted heavy truck? that combo will probably make power from 4500-8000 RPM. a stock 4.8 would be a better choice. there are so many proven easy choices out there, but every thread i see you make, you have some new, whack idea.
get a 6.0. put on some good heads, and a 224 cam in it, and actually have a truck that will be enjoyable to drive. want something crazier than that? put a turbo on it. it will actually make power you can use. do some research. keep it simple.
Old Feb 16, 2008 | 12:31 PM
custom 68's Avatar
sounds fun...
Old Feb 16, 2008 | 01:06 PM
PathfinderJr's Avatar
If you did that, your truck would be a dog yet sound cool at an idle. This idea sounds crazier than mine of eventually wanting to drop a 4.8 crank in a 6.0 block for some high winding fun. You know, when money is no object, cause until then I'll just be having fun with a regular 6.0.
Old Feb 16, 2008 | 01:20 PM
hirdlej's Avatar
You will simply never do it because 90% of the ****-a-mamie ideas thrown around this forum never happen.
Old Feb 16, 2008 | 01:53 PM
dirt track racer 81's Avatar
you would need to spray a 200 shot off the line to get it movin..even that prolly wont even pull a 2.0 60'
Old Feb 16, 2008 | 02:45 PM
well considering im planning on a 5.13 gear
a custom grind cam with caddy lifters
90mm ported throttle body on a professional products intake yea i know heat sink but it has proven power at high rpms----------------------
i already have the internals and soon to have some 035 stage 3s
then im gonna get the compression down low havent decided how low yet
and put me a turbo on there
7500 wot shifts
4k stall
built to hell and back tranny
and yea i know heavy *** truck right i failed to mention this is going on a tube frame with a custom bag setup so there goes some weight
no more 4x4 theres some more shedded
the whole bed area is getting cutoff and im making a set of fiberglass bedsides to match the fenders for it with tubing for support
but i dont want the rear end to be two lite so im putting to spares back there
imd---i think outside the box try it some time
if i wanted to be like every1 else why even mod my truck???
Old Feb 16, 2008 | 02:46 PM
o yea did i fell to mention how badass it would sound shifting at 7500rpms
Old Feb 16, 2008 | 03:16 PM
nightrunner's Avatar
Mr. Obvious
this motor is going in a TRUCK! think torque not horsepower
Old Feb 16, 2008 | 04:13 PM
so whats te use in all torque???
itll never hookup with **** tons of torque
and break rearends every other weak
im not to sure on taking the 4x4 out or not but still how many times to u go mudding and see low rpms?????
hmmmm i never do
