Crankshaft pulley
Old May 28, 2018 | 06:10 PM
Sierraman02's Avatar
Default Crankshaft pulley
i am having a very hard time getting my crank shaft pulley bolt off I have a breaker bar and a 2 foot pipe and it still won’t come off should I try heat next?
Old May 28, 2018 | 06:16 PM
03sierraslt's Avatar
Impact gun.
Old May 28, 2018 | 06:23 PM
Do not have a larger impact then what I have tried
Old May 28, 2018 | 06:27 PM
FFDP's Avatar
You can heat the bolt up and hope the heat transfer good into the crank. Don't go crazy round the pulley because you'll melt the front cover oil seal.
Old May 28, 2018 | 06:52 PM
Any better ideas then heating it up?
Old May 28, 2018 | 07:06 PM
FFDP's Avatar
A longer pipe or a stronger impact is about all I got for ya.
Old May 28, 2018 | 08:37 PM
suppose I could buy a air impact
Old May 28, 2018 | 08:41 PM
RedXray's Avatar
100% Redneck
Just buy a cheap torch from Lowes or Home Depot. Used a torch and impact to remove mine. Then used an Autozone free rental (Chrysler type) balancer tool.
Old Jun 19, 2018 | 12:21 PM
Drspencer's Avatar
5 Year Member
I got a Snap On MG725 about 7 years ago off eBay for $100. Check eBay and Craigslist for used tools. Also, your fittings may be restricting airflow. Check out Milton high flow fittings. Night and day difference.
