compression question
Old Jan 20, 2008 | 10:51 AM
jkwalkercchs's Avatar
Arrow compression question
Compression: 64cc - 10.23, 66cc - 9.56, 70cc - 9.77
Compression Height: 1.315
Bore: 3.902
Rod: 6.125
Pin Size: .927 x 2.500 - 118 Gram Pin
Ring Grooves: 1.5mm 1.5mm 3mm
3.0cc Valve Reliefs
Manufactured from Forged 2618 High Strength Alloy.
im totally lost any help would be appreciated
my heads are 57ccs so what would this equal??
whats the max comp ratio on pump gas
Old Jan 21, 2008 | 08:39 PM
knuckles's Avatar
right around 12.2:1 good for na
Old Jan 21, 2008 | 08:51 PM
Derek @ EDO's Avatar
FormerVendor
http://www.c5frc.com/calculators/Com...Calculator.htm
walledition
Feb 24, 2026 03:27 PM
11MPG
Sep 10, 2015 08:34 PM
Boyes50
Sep 8, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
