Comp 918
Old 02-25-2010, 05:45 PM
Mrgoodwrench3's Avatar
Originally Posted by EthanH
Custom spec Patrick G from EPS, havent gotten it yet. Just putting together a cam package. I was going to to a package deal from EPS with 918s but I keep reading about 918s breaking, even the new batch that supposedly has fixed the problem.
I am looking for a cam spec too. What is EPS ? How can I get a hold of Patrick G ?
Old 02-25-2010, 05:49 PM
EthanH's Avatar
EPS is engine power systems which is a company. www.guerragroup.com and click on motorsports and you can email him.
Old 02-25-2010, 06:45 PM
LS1 Tech Veteran
Steve Bryant's Avatar
I think that some of you are looking at some older threads. Take a look at this more recent thread on the 918s https://ls1tech.com/forums/generation-iii-internal-engine/1238202-new-style-918-springs.html.
I've been running the older 918s without problem, as have many others. As long as you respect the design valve lift limits and verify that you have enough clearance to avoid approaching coil bind, you should be fine. The PAC springs are excellent springs too from everything that I know. But the fact that some people have had trouble running the Comp 918s with cams pushing or exceeding valve lifts of .600 does not make them a bad spring. I would use them again without hesitation.
Steve
Old 02-25-2010, 09:16 PM
EthanH's Avatar
Yeah I never knew what the problem exactly was, thought I remembered something about a bad batch. Thanks though!
Old 02-25-2010, 09:24 PM
PT's Slowest Truck
budhayes3's Avatar
I remember seeing multiple threads with pics of busted silver springs on Tech, and I don't believe that the associated cams had extreme lift numbers either...it's enough that I'm spooked. When I build my LQ9 I'm planning a cam around 220/224 .575/.575 112, and I'm going to use the PAC 1218's.
Old 02-25-2010, 09:53 PM
speedaddict's Avatar
it was a bad batch...I've been running mine with no problems.
Old 02-25-2010, 09:58 PM
PT's Slowest Truck
budhayes3's Avatar
That's cool man, how many miles so far?
Old 02-25-2010, 10:13 PM
james8997's Avatar
im runnin 918s with no issues.
Old 02-26-2010, 02:01 PM
10k so far
Old 02-26-2010, 02:02 PM
Z'06's Avatar
When you can buy PAC 1218 springs for only $122.95, which is less than what you would pay for Comp 918 springs on Google Shopping, why is there any debate?
Quick Reply: Comp 918
