Which Color Oil Pump O-Ring - '01 ECSB 5.3L
Old Mar 10, 2010 | 11:55 AM
Ferocity02's Avatar
Default Which Color Oil Pump O-Ring - '01 ECSB 5.3L
I'm compiling a list of parts I need for my cam/spring/lifter swap. There are two oil pump o-rings, a blue/green and a red one. There is conflicting information online about which one I need.
#12557752 - Green
#12584922 - Red
Speed Engineering suggests I need the red one. Anyone?
Thanks!
Old Mar 10, 2010 | 12:07 PM
CODE4LS1's Avatar
I have always used a true blue one....it's nice and thick. I do not have a part number though, sorry man. I have also used the red one before the true blue came out in case that helps.
Old Mar 10, 2010 | 02:00 PM
hirdlej's Avatar
The red one is what you need. Unless you bought the Lingenfelter high pressure pump, they include a black or a blueish-green one. In that case, you use the blueish-green one.
Old Mar 10, 2010 | 08:30 PM
regcabls6's Avatar
red for sure! green is for the car pick up tube.
Old Mar 10, 2010 | 09:07 PM
BlownChevySS's Avatar
When I tore down my motor, I found the blue/green one (car type) in it from factory. I was advised go red because it was for trucks, and have had no issues whatsoever. Go red.
BTW, the red one is thicker, not the blue/green one.
Old Mar 11, 2010 | 02:39 PM
Tootall's Avatar
red . . . unless you like not having oil pressure on start up !
Old Mar 11, 2010 | 09:44 PM
budhayes3's Avatar
PT's Slowest Truck
Red, the blue-green one is not thick enough. Many guys have found this out the hard way, I've read multiple threads about it...
Old Mar 11, 2010 | 10:36 PM
fredkj3's Avatar
whatever you dont reuse old one.... haha i did and i had no oil pressure.... i got a redish orange one from GM.. but the one that came out was green... go figure!!!!
5.3Okasai
Mar 9, 2022 01:07 PM
Bluchevypick
Aug 18, 2015 09:11 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
