CNC lvl 3 heads and cam or supercharger?
Old Jan 28, 2011 | 03:47 PM
Petey62782's Avatar
MASS seller approved
Default CNC lvl 3 heads and cam or supercharger?
I'm trying to decide what will yield the best #s for money spent I was thinking Patriot Performance #723-2019
GM LQ9 6.0L Stage III Cylinder Heads
72cc Combustion Chamber
With comp xr265 cam 212 /218 or go with a magna charger either a maggi 112 or Tvs style. The heads and cam will set me back 2000 and a used charger is 3000-4000 . I'm not sure which way to go. This is all going on a LQ9 with LT's , twin fans,bbk 80 mm polish/ported, K N intake , Gibson cat back , FLT 4l65 lvl5 and 2600 stall, and a tune. What #s could I expect gain from both alone or together? Also has any one used those heads before? Sorry for the long post
Old Jan 28, 2011 | 03:52 PM
53bowtie's Avatar
The cam is way undersized for the motor and the heads. If you go the heads route go with a cam at least in the mid 220's for duration. If your wanting of the line torque then the maggie is probably the way to go.
Old Jan 28, 2011 | 04:35 PM
Petey62782's Avatar
Thanx Tom . I am looking for off the line. The reason I was looking at the small cam is from what I've researched that cam was said to be better for low end but what I read could be wrong. How much HP/TQ could be gained from the charger and same question for the heads and cam ?
Old Jan 28, 2011 | 10:14 PM
53bowtie's Avatar
The 212/218 is a good low end cam in a 5.3.....IMO it would be a baby cam in a 6.0. If it were me I would go with a tr220 or 224. That being said, I think you would be happier with the off-the-line power a supercharger would provide as oppose to a head/cam combo which would really help you in the mid to high power band. I think a maggie with your mods would be capable of putting down 500 at the wheels.
I must say though I have not done a supercharger on any of my setups so I can not give you personal or real world experience just what I have read and researched and seen others do on here.
Old Jan 29, 2011 | 07:09 PM
swift700's Avatar
I'd vote TVS supercharger for launching power. If you decide to go the heads and cam route, you might want to consider a higher stall torque converter to get you up into that stronger part of the power band.
Old Jan 30, 2011 | 01:03 AM
TX Tahoe Z71's Avatar
Hard to beat a blower for low end. I blow the tires out at half throttle from a stop in my heavy tahoe and a stock stall.
Old Jan 30, 2011 | 08:10 AM
03sierraslt's Avatar
If you want torque then get a blower. I ditch'ed my past blower setup to do something different (Heads & Cam) It didnt last long. I went back to a blower.
bighouse
Sep 27, 2015 12:37 AM
JFortner5
Aug 12, 2015 08:46 PM
Three6GMC
Aug 3, 2015 07:53 PM
BennyB
Aug 1, 2015 08:48 AM
steves86ta
Jul 28, 2015 10:21 AM
