clearance
Like TXsilverado keep saying, lift has very little to do with PTV clearance. Duration is what you want to worry about. And no, I don't see you having any problems with that cam you mentioned. But the only way to know is to measure it. Its like everyone who asks what pushrod length is right for them. No one in the world is going to be able to give you a correct answer. They can guess and hope to be right but the only way to know for sure is to measure.
I have a great tuner that's a wiz with VVT cams. I also tow a small
trailer with 2 HD's all over. 2000lbs. and a full bed with tools and suitcases.
so a lose conv is out of the picture.
Gamble, are you saying a .600 lift cam will fit without any VTP probs ?
is there valve reliefs on newer gen-4 5.3 pistons ? it's a LH9 motor,
not much is known about them.
On the stall factor, unless you are towing more than 6,000lbs on a regular basis a 3200 stall will be fine as long as you have a good trans cooler.
zblee
Nov 11, 2015 12:41 AM
lxcoupe
Oct 26, 2015 10:13 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
