Cleaning Up Stock 5.3 Heads?
Old Mar 7, 2010 | 02:06 AM
Ferocity02's Avatar
Default Cleaning Up Stock 5.3 Heads?
I'm going to be do some engine repairs on my 90k milee '01 ECSB in a couple weeks. I will be changing the lifters, cam, and probably timing set along with all of the required gaskets. I will have the heads off and disassembled for new valve seals as well. Would it be worth the time and effort to clean up the ports in these heads? Is there much cleaning that can be done? All I have is a Dremel so I'm not going to be able to get in the ports very deep or remove a lot of material.
Just curious, that's all.
Old Mar 8, 2010 | 11:42 AM
Ferocity02's Avatar
Anyone?
Old Mar 8, 2010 | 12:50 PM
CODE4LS1's Avatar
If you you're doing it yourself and know where to remove material and where NOT to, then I say go for it.
Old Mar 9, 2010 | 11:17 AM
budhayes3's Avatar
PT's Slowest Truck
The 5.3 heads can be improved upon, WCCH offers, or used to offer (not sure if they still do), a StageI 5.3 head. Not sure how much meat and what shape to make the ports though, and I doubt that the dremel will get in deep enough to maximize the ports, but as long as you don't go too crazy and don't disturb the ports in a way that will cause turbulence, I say go for it. I'd polish the combution chamber while I was in there if it were me.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
06 4.8
Jul 15, 2015 07:17 PM
