cleaning deposits on 6.0 pistons
Old Mar 26, 2006 | 01:27 PM
greentahoe's Avatar
Default cleaning deposits on 6.0 pistons
the pistons on my new motor have some carbon buildup on them. Would it be OK if I blasted them with carb cleaner and wiped them down?? Im worried about it dripping down the cylinder walls....
Old Mar 26, 2006 | 02:07 PM
moregrip's Avatar
what a rush!
no big deal. you'll have to wipe down the cylinder walls as well. I like to coat them with marvel mystery oil personally.
Old Mar 26, 2006 | 02:31 PM
TurboGibbs's Avatar
When you asked me about it before I was assuming you had the engine apart. If you are worried about the carbon on top of the piston I would just scrape the heavy stuff off and leave it at that. They will get carboned up again within the first few thousand miles anyway.
Old Mar 26, 2006 | 02:35 PM
greentahoe's Avatar
sounds good. Maybe the meth will help to clean them a bit as well. Should I coat the walls with the mystery oil as well?? Or should I just do a light coat of Mobil 1? I really appreciate it!
Old Mar 26, 2006 | 02:39 PM
TurboGibbs's Avatar
Any oil will do. It will get lubed well right after start up anyhow.
Old Mar 26, 2006 | 03:44 PM
Danville Performance's Avatar
Yeah the meth will probably clean the pistons like nos does and they will stay cleaner longer. Carb cleaner is what I use when the heads are of to remove the carbon build up when doing a build up or just a head job. I would clean them if you have it apart so they will be equal compression across the board or as close as possible. It would be like having the oilpan off and not removing the sludge in the bottom before reinstalling it.
Old Mar 26, 2006 | 03:54 PM
moregrip's Avatar
what a rush!
ferrellrooster
Mar 6, 2025 03:22 PM
Idryfly5
Sep 2, 2022 08:55 PM
greedygenius
Sep 3, 2015 06:51 AM
05GMC4.8
Aug 7, 2015 09:55 PM
justuc
Jul 24, 2015 11:52 PM
