Chevy 5.3 cam swap- things to replace
Old Dec 14, 2009 | 01:52 PM
  #41
01SilvyZ71's Avatar
sweet thanks, i know someone with an air compressor. now to find the adapter..
Old Dec 14, 2009 | 02:31 PM
  #42
Atomic's Avatar
I have a gauge for that
I have one I will sell you
Old Dec 14, 2009 | 03:21 PM
  #43
xlcooplx's Avatar
when are you planning on doing the cam swap?
Old Dec 14, 2009 | 03:56 PM
  #44
01SilvyZ71's Avatar
the spark plug adapter? pm me...
  #45
01SilvyZ71's Avatar
plan on doin it this weekend depending on if i can have all the parts in or not.
Old Dec 14, 2009 | 06:08 PM
  #46
Atomic's Avatar
pm sent
Old Dec 14, 2009 | 08:56 PM
  #47
eallanboggs's Avatar
Don't go overboard with the air pressure. If you use too much the crank will spin. You MUST have the piston as close to TDC as possible so it doesn't try to rotate when the air pressure is added. Stay under 50lb psi. That's more than enough to hold the valves up with the piston at TDC.
Old Dec 14, 2009 | 09:00 PM
  #48
black04's Avatar
You could lock the flywheel..
Old Dec 14, 2009 | 09:06 PM
  #49
01SilvyZ71's Avatar
ill be sure and keep this thread handy this weekend. now for the air gaskets that the ls1 article calls for, do i need those or was it just for the the camaros and such?
Old Dec 15, 2009 | 02:50 AM
  #50
I dont kno if this was mentioned or not, but if you have any old spark plug wires of an old sbc motor. Cut the ends off and use those to keep the lifters up. cheap alternative to metal dowels and the store easier than wooden dowels.
